Orbi WiFi 7 RBE973
Reply
no internet
cdvasquez526
Follower
no internet
we noticed some devices signed into the Netgear wifi extender suddently stopped working or we were getting the device was not connected to the wifi.  we turned the netgear device off and then turned it back on, proceeded to log into the wifi extender network and password.  But, when I log in, the connection shows as "Connected, no internet". how do I get connected again?  Thanks!
Model: PLW1010|PowerLINE 1000 Wireless adapter
Message 1 of 2
Guru
Re: no internet
If you have the plw1010 it needs that powerline connection back to the router to work. Basically its saying "yes your device connected to the extender, but the routers not connecting to the extender".
And many things impact powerline devices.
Things that add interference:
electronics going bad
old/cheap/bad wiring
gfci outlets
arc fault outlets
surge protectors
high draw appliances
certain cell phone chargers add interference.
So something to try is move the extender to the same circuit the powerline device connected to the router is on and test it. If it connects and works, then its probably something in the power system adding interference.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 471 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
