× Introducing the new Orbi 770 Series Mesh System. To learn more click here.
Orbi WiFi 7 RBE973
Reply
password
williamsf1
Follower
password
i can conect any devices it asks for the password the same as the router but then says its wrong and wont conect
Model: EX6120|AC1200 Dual Band WiFi Range Extender
Message 1 of 6
Guru
Re: password
Is this the initial installation, or did it work correctly before?
Message 2 of 6
Leejohnst
Star
Re: password
I’m having the same issue where it worked before, since getting a new broadband  it’s say incorrect password when entering the same password
Message 3 of 6
Guru
Re: password
While you're seeing a similar symptom, your problem might not be the same.
One option is of course to reset the extender, and try setting it up from scratch.
Message 4 of 6
Leejohnst
Star
Re: password
Yes I’ve factory reset the extender a few times now. It is still saying incorrect password after doing the initial set up via wps.
Message 5 of 6
Guru
Re: password
Let's stick to one thread  (continuing this conversation on the one you started).
Message 6 of 6
Discussion stats
  • 5 replies
  • 910 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi 770 Series
