- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
range extender with ethernet cable vs as an access point
- Mark as New
- Bookmark
- Subscribe
- Permalink
I've been using a EX7300 as a range extender to a single access point, but have had some dropouts. I was planning to set up a second access point.
As I read it, it looks like the EX7300 can be used also as an access point OR as a hard wired range extender. In this application, what would be the difference? WOuld it perform better as a range extender or as an access point? - in either case, it would be connected to the router via ethernet.
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
As an access point the EX7300 needs to be hardwired in. So there isn't a "hardwired extender mode".
Its simply access point mode.
If you have it hardwired in and running as an access point, it'll actually function faster than it would in extender mode. In extender mode, the wireless chip has to send/recieve from router---->extender and then extender---->devices. And they can't do both at once. So they take a 50% speed hit. They don't take that same speed hit when its hardwired in.
also in AP setup: RAXE500->EAX80
1.4gig download/50mbps upload from Xfinity
We’re members of the public helping out on our own time.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: range extender with ethernet cable vs as an access point
a follow-on: If the answer is range extender, would I need to change any setup, other than plug directly in the ethernet?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks. I had had a good understanding of access points ans range extenders, then I read some Netgear documentation which seemed to mean you could connect a range extender using ethernet, and I didn't understand. It turns out that documentation was only talking about the CONFIGURATION process! All is good. Using it now as an access point.
Related question: When used as a range extender, Google Speedtest indicated ~ 190MBPS download. When I changed it to an access point, that dropped in half, in virtually the same location. Does MU-MIMO slowly train itself to improve? (either way, I've plenty of BW for anything I need.)
- Mark as New
- Bookmark
- Subscribe
- Permalink
are you using the smart connect?
2.4ghz is much much slower than 5ghz. so it matters which band you're connecting to for speedtesting.
And in access point mode, its actually should have faster speeds than extender mode.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I am using Smart Connect BUT before realizing the EX7300 could be used as a AP, I had purchaced a TP-Link AP and set it up (I'm going to return it). On the 5GHz band, it was giving me about the same results as does the 7300 now.
I have 1 laptop, a streaming TV, and several home digital assistants where they would be served by the AP. On Smart COnnect, will they all tap into the 5GHz band? If I were manually setting it up, I would put the low bandwidth devices on the 2.4GHz. WIll this make any difference to my percieved speed? ( separate from the 180GBPS/90GBPS speedtests - I know they won't affect that.)
- Mark as New
- Bookmark
- Subscribe
- Permalink
smartconnect will move devices between the 2.4ghz and 5ghz bands. 5ghz is much faster but it doesn't broadcast as far.
It does tend to balance devices out between the 2 based on bandwidth and signal strength.
