- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
resetting netgear router password
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello, I have found my old netgear router. I have the user name but forgot my password to connect to the WiFi. Please help
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: resetting netgear router password
There is a physical reset button. Push it for 8 to 10 seconds and the router will reset to factory configuration. The default username and password are usually admin and password, respectively.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
No, admin is the username to log into the router's management page. The default Wi-Fi name and password may be printed on a label attached to the router. If there is no label, then you may have to connect a computer to the router with an Ethernet cable, log in and set up the Wi-Fi network.
If you have the model # of your router, then you can download instructions to set up your router from http://support.netgear.com.
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
