× Attn: Nighthawk Pro Gaming members, we have recently released firmware to address a critical security vulnerability. For more information click here. .
Orbi WiFi 7 RBE973
Reply
security when using ex6000 as an AP
chriswalter
I'm trying to use an EX6000 as an access point with a BT home hub 4 as my main router. The only way I can get it to work is to turn off the security and have the new network I've created unprotected - if I add security it flips from access point mode to extender mode and loses the ethernet connection.
Is there a way around this?
thanks
Chris
Model: EX6000|AC750 Dual Band WiFi Range Extender
Message 1 of 4
DarrenM
Sr. NETGEAR Moderator
Re: security when using ex6000 as an AP
Hello Chriswalter
Make sure you are using the latest firmware on the EX6000 also are you using WPA2 security.
DarrenM
Message 2 of 4
chriswalter
Firmware is up to date and WPA2 security wasn't an option.
Do I need to set it to a specific IP address outside the range of the router's IP addresses?
Message 3 of 4
DarrenM
Hello Chriswalter
You shouldn't have to do that? and WPA2 is not a option on your main router?
DarrenM
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 3142 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
