× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
sip alg
arxcakes10
Follower
sip alg
Ive started a new job that requires me to have SIP alg option on my router as some routers have this permanently enabled or disabled, which netgear routers have this option?
Message 1 of 2
TheEther
Guru
Re: sip alg
Not sure why you posted this in Range Extenders forum.
Anyway, AFAIK, the SIP ALG option is a standard option on Netgear routers.  You can always double check the online documentation at http://support.netgear.com.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 2393 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
