- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
stretching the signal
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi there, I have two questions:
1) is there a possibility to connect satellites amongst each other with an ethernet LAN cable to strech the signal?
2) Is there a Netgear Powerline system that works with the Orbi system?
Thanks!
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
@Ocin70 wrote:Hi there, I have two questions:
1) is there a possibility to connect satellites amongst each other with an ethernet LAN cable to strech the signal?---yes you can connect satellites to each other over a lan cable.
2) Is there a Netgear Powerline system that works with the Orbi system?---orbi doesn't have powerline built in so any powerline system that sets up/connects, should work.
Thanks!
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks!
- Mark as New
- Bookmark
- Subscribe
- Permalink
