Reply
unable to access login page for extender
mrr42
I misplaced the admin password for this network extender (model EX6150) and needed to recongifure a few things and upgrade the firmware so I did a factory reset thinking I could simply start over.  I was able to get the extender to connect to my router using WPS and basic connectivity seems to be working fine.  I do want to change some of the security settings, check the firmware levels and customize things to my needs though.
After some intense investigation using the web interface (mywifiext.* and 192.168.0.250 didn't work), I was able to determine the IP address of my extender and was able to bring up the "new extender setup" page.  I tried filling out the page again (a number of times) but I don't seem to be able to get by that screen.  I then tried to guess at the admin login page URL (unsuccessfully) to try to circumvent this obstruction but I guess I am not clever enough to guess it.  I think if I could get the URL to enter into the browser to access the admin login page I might be able to use the default credentials to login and resollve the issue but as yet I have not been able to guess it.
Any help/suggestions are appreciated.
Thanks,
Model: EX6150|AC1200 WiFi Range Extender
Message 1 of 3
Accepted Solutions
mrr42
Re: unable to access login page for extender
I was FINALLY able to get this resolved.  I needed to purchase an RJ45 connector (I have a MacBook Pro with only USB-C ports), hook it up to the EX6150 while I reset to factory defaults and eventually after a little poking I go to the logon screen.  Persistance paid off.....
Message 2 of 3
All Replies
mrr42
Message 2 of 3
Christian_R
NETGEAR Employee Retired
Hello mrr42,
Thanks for providing an update to the post as it may help others in the future.
Christian
Message 3 of 3
Discussion stats
  • 2 replies
  • 458 views
  • 0 kudos
  • 2 in conversation
Announcements
