- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
wireless connection to upstream access point EAX20
- Mark as New
- Bookmark
- Subscribe
- Permalink
Can the EAX 20 range extender connect to any access point wireless eg used in Rv at different locations to create secure network. Thanks
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: wireless connection to upstream access point EAX20
Should be able to yes.
I would review installation guides and user manual for setting this up.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hoping some has done this as the manual doesnot address access points outside the network
- Mark as New
- Bookmark
- Subscribe
- Permalink
Are you talking about connecting to an RV parks wifi or connecting to your own hot spot in the park?
Makes a big difference.
Reason why is most rv parks have some sort of gateway/terms and conditions that you have to accept or login with to use their wifi.
A standard extender won't work.
You'd want something like a travel router that supports wisp mode.
Netgear hasn't made one in a long time and its far behind on technology.
So if you're planning on connecting with an existing wifi that needs login/t&c then I'd go another route versus a standard extender.
Or you won't be able to use it at most parks.
