Reply
Someredyeti
Follower
wn2500rp v2 green blinking power button
Hi today my range extender stopped working, it got disconnected during the firmware update. now the light just flashes green. ive tried running the reset without a cd and the factory reset button seems to do nothing. when i set my ip 192.168.1.1 and try to ping it i get no response. is there anything i can do?
Model: WN2500RPv2|N600 WiFi Range Extender
Message 1 of 2
DarrenM
NETGEAR Moderator
Re: wn2500rp v2 green blinking power button
Hello someredyeti
You may want to contact support if the extender is still under warranty the firmware update may have bricked the unit.
https://www.netgear.com/support/contact.aspx?cid=wmt_netgear_organic
DarrenM
Message 2 of 2
Discussion stats
  • 1 reply
  • 1620 views
  • 0 kudos
  • 2 in conversation
Announcements
