Reply
Can i downgrade a firmware of a router?
Hello,
If i purchased wgr614v9 router with firmware 1.2.XXX
I would like to downgrade it to V1.0.15_4.0.3 - will it damage the unit?
Link to the desired firmware
Thanks,
Eran.
Luminary
Re: Can i downgrade a firmware of a router?
YES and it will not damage it...........Smiley Happy
VPN Case Study
VPNCASESTUDY.COM
"Our Second To None VPN Related Setup Case Study[/COLOR][/URL]
"One Stop Solution To Your Netgear VPN Connectivity"
*Visit the site for Non-VPN related Doc & Links* [Windows & Mac user/support]
June Mizoguchi-
It is very frustrating. I downgraded to version V1.0.15_4.0.3 which allows me to select WPA while using repeater. BUT it doesn't work. I'm able to configure everything but can access the internet only when using WEP security (or None).
I cannot understand why WPA feature is enabled in the interface and listed in the description on the right as one of the valid option yet it doesn't do the job.....
I don't want to use WEP thus I think I don't have anything to do with the newly purchased unit.
Does someone managed to make it work?
Eran.
Discussion Stats
  • 2 replies
  • 6539 views
  • 0 kudos
  • 2 in conversation
Top Contributors
