Reply
Initiate
Can't access admin page (www.mywifiext.net)
After wasting my time for 30 minutes trying to get www.mywifiext.net to work, here's what I did:
--I had already set up the WN3500RP using WPS.
--Connected to the WN3500RP via Ethernet (i.e. ran a CAT6 cable from my laptop to the Ethernet port on the WN3500RP).
--Went into my router's DHCP table to get the IP address of the WN3500RP.
--Entered the IP address as the URL (e.g. 192.168.1.144).
--Changed the WN3500RP to use a static IP address outside the range of my router's DHCP list (e.g. 192.168.1.163). That way it will always be at .163 so I don't have to hunt for it every time I want to access the admin page.
--Entered the new static IP address as the URL (e.g. 192.168.1.163).
--Updated the firmware and customized the WN3500RP.
Hope that helps!
Re: Can't access admin page (www.mywifiext.net)
admin
Privat
NETGEAR Moderator
Hello Rajeckis
what issue are you having can you give some detail on your setup and what extender you have.
DarrenM
Discussion Stats
  • 3 replies
  • 46813 views
  • 1 kudo
  • 3 in conversation
Top Contributors
