Reply
Follower
Change 5G password on WNDR3400v2
I downloaded the "Genie" and had an easy time of changing the 2.4G security code BUT I can't pull up the 5G in the genie in order to change that password too...how to I get to the 5G security settings?
Re: Change 5G password on WNDR3400v2
You have to go to your internet browser and type in the address bar 192.168.1.1 then type in your admin and password (default is password) and you can access all your settings from here. Netgear genie is limited on router settings. BTW you can change your router password here too but it's tricky. Took me awhile to figure it out. Go to Administration and click it. You'll see a blank area where password setup is supposed to be. Just click the blank area and there you go. I thing they blank it out on purpose for security reasons.
Luminary
WNDR3400 is not extender. It is wireless N router
belongs to root of http://forum1.netgear.com/forumdisplay.php?f=33
REPOST
VPN Case Study
VPNCASESTUDY.COM
"Our Second To None VPN Related Setup Case Study[/COLOR][/URL]
"One Stop Solution To Your Netgear VPN Connectivity"
*Visit the site for Non-VPN related Doc & Links* [Windows & Mac user/support]
June Mizoguchi-
Discussion Stats
  • 2 replies
  • 12413 views
  • 0 kudos
  • 3 in conversation
Top Contributors
