Reply
How to Connect to 5GHz Channel?
Hi, I've got a WNDR3700v2 that's an access point for an XP and a Win7. On the Win7 machine, I can only connect to the 2.4GHz channel.
When I click on the signal bars in the task panel and bring up the Network and Sharing Center, it shows I'm connected to the 2.4GHz channel. If I click on View your active networks, Connect or disconnect, it shows I'm connected to the 2.4GHZ channel, and it shows some neighbor's networks, but it doesn't even list my 5GHz channel.
When I click on Manage Wireless Networks in the left side menu, it says Windows tries to connect to these networks in the order listed, and it lists my 5GHz channel first, and the 2.4GHz channel is listed second, so that looks right, but for some reason it's not connecting to the 5GHz channel.
Does anyone have any ideas how I can make the 5GHz channel show up so I can connect to it?
Luminary
Re: How to Connect to 5GHz Channel?
pc must support dual band (dual band wifi adapter )
VPN Case Study
VPNCASESTUDY.COM
"Our Second To None VPN Related Setup Case Study[/COLOR][/URL]
"One Stop Solution To Your Netgear VPN Connectivity"
*Visit the site for Non-VPN related Doc & Links* [Windows & Mac user/support]
June Mizoguchi-
Thanks for the reply June. Here's my computer adapter info from msinfo. It doesn't specifically say "dual band", but since it mentions b, g and n, I assumed it was. What's your opinion?
Name [00000011] Dell Wireless 1502 802.11b/g/n
Adapter Type Ethernet 802.3
Product Type Dell Wireless 1502 802.11b/g/n
Installed Yes
PNP Device ID PCI\VEN_168C&DEV_002B&SUBSYS_02041028&REV_01\001517FFFF24141200
Last Reset 2/10/2012 3:41 PM
Index 11
Service Name athr
IP Address 192.168.1.7, fe80::18aa:5efc:58f8:f334
IP Subnet 255.255.255.0, 64
Default IP Gateway 192.168.1.1
DHCP Enabled Yes
DHCP Server 192.168.1.1
DHCP Lease Expires 3/13/2012 11:58 PM
DHCP Lease Obtained 2/12/2012 10:58 PM
MAC Address E4Smiley Very Happy5:3D:88:2F:2E
Memory Address 0xFE400000-0xFE4FFFFF
IRQ Channel IRQ 17
Driver c:\windows\system32\drivers\athrx.sys (9.1.0.328, 2.26 MB (2,374,656 bytes), 12/5/2011 3:57 PM)
Luminary
Only supports 2.4Ghz
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
Thanks June. For my education, what identified that it supports 2.4GHz only?
Luminary
B/G/N
Dual band- A/B/G/N
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
Thanks very much.
TBW Aspirant
I have a 3400 router and have the same issue, the blue light never blinks. Looking and my lan card on my laptop, it does support 5GHz:
Realtek RTL8188CE Wireless LAN 802.11n PCI-E NIC
I tried enabling 11n AdHoc but that didn't do it.
Any suggestions?
Luminary
Any suggestions?
ad-hoc are not going do any for connecting to wireless router . ad-hoc is for other wifi device to connect your laptop directly
if you are wireless do NOT support 5Ghz than not use of trying. replace the PCI-C card with dual band support card or buy USB wifi adapter instead
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
How can I tell if my Network Adapter accepts dual band. I am running a Atheros AR9285 Wireless Network Adapter. It was pre-loaded onto my laptop.
Luminary
http://www.qca.qualcomm.com/media/product/product_79_file1.pdf
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
Discussion Stats
  • 10 replies
  • 35478 views
  • 0 kudos
  • 4 in conversation
Top Contributors
