Reply
Password doesn't work
I have a WN3000RP range extender. I tried using the same password for my router like instructions say to do and it won't connect. I tried connecting with a wifi computer and my iPad. I tried going to mywifiext.net and the page won't load either. Thanks
Luminary
Re: Password doesn't work
Make sure to use WPA2 and reset the extender and try setup again
VPN Case Study
VPNCASESTUDY.COM
"Our Second To None VPN Related Setup Case Study[/COLOR][/URL]
"One Stop Solution To Your Netgear VPN Connectivity"
*Visit the site for Non-VPN related Doc & Links* [Windows & Mac user/support]
June Mizoguchi-
I have a DIR-825 router. I don't know how to change WPA2. I can get to all the router settings and such but theres so much stuff I can go to. Would it be under Internet, wireless, network or usb settings?
Luminary
Wireless setting
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
I have the same problem and I ensured that both had WPA2
I cannot access the wizard either via wireless
I tried with an ethernet cable but it did not really identify the passcode
Discussion Stats
  • 4 replies
  • 2101 views
  • 0 kudos
  • 3 in conversation
Top Contributors
