Reply
Follower
WN3000RP Range Extender, Is the ethernet input or output?
[ Edited ]
Im just looking at getting a WN3000RP Wireless range extender. I want to use it for when im at university, not to pick up and re-distribute a current wireless signal but to plug into my ethernet connection in my room so that i can have wireless internet. I noticed it has an ethernet connection but cant find anywhere if its an output to connect to a non wireless device or an input?! any help would be greatly appreciated! thanks!
Luminary
Re: WN3000RP Range Extender, Is the ethernet input or output?
You should able to use both
VPN Case Study
VPNCASESTUDY.COM
"Our Second To None VPN Related Setup Case Study[/COLOR][/URL]
"One Stop Solution To Your Netgear VPN Connectivity"
*Visit the site for Non-VPN related Doc & Links* [Windows & Mac user/support]
June Mizoguchi-
Discussion Stats
  • 1 reply
  • 2999 views
  • 0 kudos
  • 2 in conversation
Top Contributors
