Reply
WPN824 and WGR614 - can I do a wireless bridge?
I have a desktop that chops every time I put a wireless card in it, so it's not connected to my wireless internet/network. I have a netgear wgr614 and and just bought a netgear wpn824.
Is there any way I can hook my desktop that's left out of the mix to a wireless router through ethernet and configure that router to act as a wireless adapter which hops on the wireless network?
[] desktop computer
| [] Cable Modem
[] wireless router |
| [] wireless router #2
\_______________________________________/
Wireless connection
Re: WPN824 and WGR614 - can I do a wireless bridge?
disregard the diagram, It didn't show up right here's a diagram
PC W.router W.router2 Cable Modem
I should also state that I currently have the same SSID for both routers, same channel, and different ip addresses (192.168.1.1/192.168.1.99)
DHCP disabled on the one connected to laptop
WPASK encryption enabled
Luminary
this only solution.. cable between the the unit
http://kbserver.netgear.com/inquira/default.asp?ui_mode=answer&prior_transaction_id=9367&action_code...
VPN Case Study
VPNCASESTUDY.COM
"Our Second To None VPN Related Setup Case Study[/COLOR][/URL]
"One Stop Solution To Your Netgear VPN Connectivity"
*Visit the site for Non-VPN related Doc & Links* [Windows & Mac user/support]
June Mizoguchi-
thank you for trying to help. I've been there. I'm trying to avoid a cable as it's not feasible, hence the title.
Does everyone concur that there is no other alternative?
Luminary
you need to look this..
http://forum1.netgear.com/showthread.php?t=6776
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
ishtiaq
Discussion Stats
  • 6 replies
  • 56888 views
  • 0 kudos
  • 3 in conversation
