Reply
NETGEAR CMD31T problems
So i keep getting dropped from my internet, it works extremely well otherwise. I have Cox internet and netgear CMD31T modem. The modem seems to lose signal and reset itself many times a day. I have had 4 techs come out, the last one redid all the wiring from the box outside into my apartment. New cables have been put in, I even switched my modem for another one of the same kind. Still having the problems. Here are my modem errors and such.
Time Priority Description
Fri Mar 30 23:57:00 2012 Critical (3) Started Unicast Maintenance Ranging - No Response received - ...
Fri Mar 30 23:57:00 2012 Error (4) DCC-ACK not received;CM-MAC=2c:b0:5d:af:73:40;CMTS-MAC=00:21:...
Fri Mar 30 23:57:02 2012 Critical (3) Started Unicast Maintenance Ranging - No Response received - ...
Fri Mar 30 23:57:15 2012 Critical (3) No Ranging Response received - T3 time-out;CM-MAC=2c:b0:5d:af...
Fri Mar 30 23:57:45 2012 Critical (3) Received Response to Broadcast Maintenance Request, But no Un...
Fri Mar 30 23:58:11 2012 Critical (3) Unicast Ranging Received Abort Response - initializing MAC;CM...
Fri Mar 30 23:58:44 2012 Notice (6) TLV-11 - unrecognized OID;CM-MAC=2c:b0:5d:af:73:40;CMTS-MAC=0...
Fri Mar 30 23:58:44 2012 Warning (5) RCS Partial Service;CM-MAC=2c:b0:5d:af:73:40;CMTS-MAC=00:21:a...
Sat Mar 31 09:54:30 2012 Critical (3) Started Unicast Maintenance Ranging - No Response received - ...
Sat Mar 31 09:54:30 2012 Error (4) DCC-ACK not received;CM-MAC=2c:b0:5d:af:73:40;CMTS-MAC=00:21:...
Sat Mar 31 09:54:32 2012 Critical (3) Started Unicast Maintenance Ranging - No Response received - ...
Sat Mar 31 09:54:45 2012 Critical (3) No Ranging Response received - T3 time-out;CM-MAC=2c:b0:5d:af...
Sat Mar 31 09:55:15 2012 Critical (3) Received Response to Broadcast Maintenance Request, But no Un...
Sat Mar 31 09:55:38 2012 Critical (3) Unicast Ranging Received Abort Response - initializing MAC;CM...
Sat Mar 31 09:56:11 2012 Warning (5) ToD request sent - No Response received;CM-MAC=2c:b0:5d:af:73...
Sat Mar 31 09:56:13 2012 Notice (6) TLV-11 - unrecognized OID;CM-MAC=2c:b0:5d:af:73:40;CMTS-MAC=0...
Sat Mar 31 09:56:33 2012 Critical (3) Started Unicast Maintenance Ranging - No Response received - ...
Sat Mar 31 09:56:34 2012 Error (4) DCC-ACK not received;CM-MAC=2c:b0:5d:af:73:40;CMTS-MAC=00:21:...
Sat Mar 31 09:56:36 2012 Critical (3) Started Unicast Maintenance Ranging - No Response received - ...
Sat Mar 31 09:56:49 2012 Critical (3) No Ranging Response received - T3 time-out;CM-MAC=2c:b0:5d:af...
Sat Mar 31 09:57:19 2012 Critical (3) Received Response to Broadcast Maintenance Request, But no Un...
Sat Mar 31 09:57:42 2012 Critical (3) Unicast Ranging Received Abort Response - initializing MAC;CM...
Sat Mar 31 09:58:12 2012 Warning (5) ToD request sent - No Response received;CM-MAC=2c:b0:5d:af:73...
Sat Mar 31 09:58:13 2012 Notice (6) TLV-11 - unrecognized OID;CM-MAC=2c:b0:5d:af:73:40;CMTS-MAC=0...
Sat Mar 31 10:08:18 2012 Critical (3) Started Unicast Maintenance Ranging - No Response received - ...
Sat Mar 31 10:08:18 2012 Error (4) DCC-ACK not received;CM-MAC=2c:b0:5d:af:73:40;CMTS-MAC=00:21:...
Sat Mar 31 10:08:20 2012 Critical (3) Started Unicast Maintenance Ranging - No Response received - ...
Sat Mar 31 10:08:34 2012 Critical (3) No Ranging Response received - T3 time-out;CM-MAC=2c:b0:5d:af...
Sat Mar 31 10:09:04 2012 Critical (3) Received Response to Broadcast Maintenance Request, But no Un...
Sat Mar 31 10:09:28 2012 Critical (3) Unicast Ranging Received Abort Response - initializing MAC;CM...
Sat Mar 31 10:09:57 2012 Warning (5) ToD request sent - No Response received;CM-MAC=2c:b0:5d:af:73...
Sat Mar 31 10:09:59 2012 Notice (6) TLV-11 - unrecognized OID;CM-MAC=2c:b0:5d:af:73:40;CMTS-MAC=0...
Sat Mar 31 13:06:02 2012 Critical (3) Started Unicast Maintenance Ranging - No Response received - ...
Sat Mar 31 13:06:02 2012 Error (4) DCC-ACK not received;CM-MAC=2c:b0:5d:af:73:40;CMTS-MAC=00:21:...
Sat Mar 31 13:06:04 2012 Critical (3) Started Unicast Maintenance Ranging - No Response received - ...
Sat Mar 31 13:06:17 2012 Critical (3) No Ranging Response received - T3 time-out;CM-MAC=2c:b0:5d:af...
Sat Mar 31 13:06:47 2012 Critical (3) Received Response to Broadcast Maintenance Request, But no Un...
Sat Mar 31 13:07:12 2012 Critical (3) Unicast Ranging Received Abort Response - initializing MAC;CM...
Sat Mar 31 13:07:45 2012 Warning (5) ToD request sent - No Response received;CM-MAC=2c:b0:5d:af:73...
Sat Mar 31 13:07:46 2012 Notice (6) TLV-11 - unrecognized OID;CM-MAC=2c:b0:5d:af:73:40;CMTS-MAC=0... \
and
Startup Procedure
Procedure Status Comment
Acquire Downstream Channel 843000000 Hz Locked
Connectivity State OK Operational
Boot State OK Operational
Configuration File Complete
Security Enabled BPI+
Downstream Channel 0
Lock Status Locked Modulation 256 QAM
Channel ID 1 Symbol rate 5360537
Downstream Frequency 843000000 Hz Downstream Power 0.4154 dBmV
SNR 37.0927 dBmV Correctables 49
Uncorrectables 599
Downstream Channel 1
Channel ID 2 Symbol rate 5360537
Downstream Frequency 849000000 Hz Downstream Power 0.9499 dBmV
SNR 37.3560 dBmV Correctables 0
Uncorrectables 505
Downstream Channel 2
Channel ID 3 Symbol rate 5360537
Downstream Frequency 855000000 Hz Downstream Power -0.3499 dBmV
SNR 37.0927 dBmV Correctables 0
Uncorrectables 738
Downstream Channel 3
Channel ID 4 Symbol rate 5360537
Downstream Frequency 861000000 Hz Downstream Power -0.4930 dBmV
SNR 37.9359 dBmV Correctables 0
Uncorrectables 531
Upstream Channel 0
Lock Status Locked Modulation 64QAM
Channel ID 1 Symbol rate 5120 Ksym/sec
Upstream Frequency 36100000 Hz Upstream Power 33.0000 dBmV
Upstream Channel 1
Lock Status Not Locked Modulation
Channel ID 0 Symbol rate 0 Ksym/sec
Upstream Frequency 0 Hz Upstream Power 0 dBmV
Upstream Channel 2
Upstream Channel 3
Current System TimeSmiley Frustratedat Mar 31 14:27:31 2012
I dont know what all this means, so if anyone has any suggestions or anything at all that may help I would be extremely great full. This has been an extremely frustrating process and I just want to get it fixed. I cant take the modem back and try a different one because Fry's will only give me in store credit and low and behold Frys only has 2 modems in their entire store. Go figure.
Luminary
Re: NETGEAR CMD31T problems
CMD31T is not wired network adapter.. it is wired gateway
http://forum1.netgear.com/forumdisplay.php?f=29
these units are commonly provided by the ISP so you will need to ask support with this issues.
also there is other people has complain issue with comcast but probably that thread may not fist you but there is ONLY few thread post in the past week so search from above and correct section for it.
VPN Case Study
VPNCASESTUDY.COM
"Our Second To None VPN Related Setup Case Study[/COLOR][/URL]
"One Stop Solution To Your Netgear VPN Connectivity"
*Visit the site for Non-VPN related Doc & Links* [Windows & Mac user/support]
June Mizoguchi-
Discussion Stats
  • 1 reply
  • 11790 views
  • 0 kudos
  • 2 in conversation
