Reply
connection TimeOut
Everytime I turn my WiFi on, on my computer so I can use my i phone through wi fi an error occurs..
COULD NOT JOIN NETWORK
A CONNECTION TIMEOUT OCCURRED..
With this error if turns searches, turns on, then drops off.
I have normal internet connect though it's just this wi fi problem..
How do I fix this please..
I also want it to have a password so if anyone wants to connect
to my network (computer) using the wi fi they must have the password to
join....
Luminary
Re: connection TimeOut
forum user can not help you if you don't post model and what type wireless setting you set too.
plus you are posting not under router section
http://forum1.netgear.com/forumdisplay.php?f=31
VPN Case Study
VPNCASESTUDY.COM
"Our Second To None VPN Related Setup Case Study[/COLOR][/URL]
"One Stop Solution To Your Netgear VPN Connectivity"
*Visit the site for Non-VPN related Doc & Links* [Windows & Mac user/support]
June Mizoguchi-
Hi sorry
Model is DG834GU VERSION 5
Basically when my wi fi was working you would need a password to
join it and I would like it to remain that way again..
I did however reset my net gear router to try and set a new password and
it has lead me to this error now...
I hope you can help out..
forgot to mention I have a MAC computer
Luminary
WPA2 should work
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
Discussion Stats
  • 4 replies
  • 15598 views
  • 0 kudos
  • 2 in conversation
