Reply
Novice
D6200 Download speed problems
Hi, I've just installed a D6200 to replace my existing router which has died (tp-link n adsl2+) However since installing this i have lost my download speed. I used to have no problem with youtube or the ps3 but now with this router it takes ages to download a 3 min youtube video and then it still plays intermitently. I had thought that this new netgear router would have the same ability to download as the tp-link.
Does anyone know if there is a way to fix this? as reading email etc is all perfectly fine but i can not stand the download time, this product may have to go back if there's no fix for it.
Re: D6200 Download speed problems
Some update?
I have buy a D6200 netgear router and I've updated the firmware version ( V.1.1.00.09 ),
but my download speed ( with ethernet cable ) is too slow.
I have a Tiscali ADSL 10Mbit/1Mbit but every speed test says: ~ 3Mbit ....
Could you help me?
Paolo.
Virtuoso
Try reducing your MTU size base on the required MTU size of your ISP. Here is the link on to configure it.
http://kb.netgear.com/app/answers/detail/a_id/24015
Discussion Stats
  • 2 replies
  • 7545 views
  • 0 kudos
  • 3 in conversation
