Reply
DM111PSP - Firmware issue
Hi,
I have a firmware upgrade issue with the model - DM111PSP which I hope you can help me with. The current firmware is 3.63a and I am trying to upgrade to the suggested firmware by Netgear to 3.65i. Everytime I try to upgrade I get the following message:
The firmware upgrade is failed. The selected file contains an illegal image.
I have tried everything without success, downloading with different browsers on different operating systems with winrar or winzip. Any help with this is much appreciated.
Luminary
Re: DM111PSP - Firmware issue
Did you got this unit from ISP? if so it my have branded firmware which will fail to use netgear firmware
also there is v1 and V2
If bottom of the unit does NOT say v2 and you have V1
it will make s HUGE difference as well
VPN Case Study
VPNCASESTUDY.COM
"Our Second To None VPN Related Setup Case Study[/COLOR][/URL]
"One Stop Solution To Your Netgear VPN Connectivity"
*Visit the site for Non-VPN related Doc & Links* [Windows & Mac user/support]
June Mizoguchi-
Thank you for the reply. It does not say V2 so presumably its a V1 also I think V2 is for North America. Yes it was provided by an ISP. Is there no hope ?
Regards.
Luminary
Probably not if you download v1 firmware and do not work
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
Discussion Stats
  • 3 replies
  • 2478 views
  • 0 kudos
  • 2 in conversation
