Reply
NGear CG3000D
I have the above listed wireless router and I have 3 X-Boxes hooked up (hard wired).
I can only obtain a open NAT on one and the other two are strict.
I did enable the UPnP.
The Cbl company is checking into it but you know how that goes.
I do not have a static IP but I could make the X-Boxes static if that would help. But one problem, I was looking @ the port forwarding and I can only ad the X-Box numbered ports for one X-Box. This unit does not allow me to add more/duplicate the IP's even though the ending numbers are different.
The main thing is to get the Router OPEN, not sure why it will only let one open.
One more thing, whoever signs on first (w/the X-Box) gets the OPEN port or
?? then the other two are strict.
I looked in the ADMIN section of the router and can not find a enable tab/box for this feature. I can only ENABLE the UPnP.
Thanks again for the help,
Jim
Luminary
Re: NGear CG3000D
usually multiple xbox will not work behind the router.
your few options are to get static IP from your cable company and assign to xbox but I don't CG3000D will not help either.
you will need like below
cable modem <---> switch <---> standard wireless router.
behind the switch you will have to hook up xboxes.
if you have 3 xbox and router for rest of pc etc, you will need 4 public IP from your ISP
VPN Case Study
VPNCASESTUDY.COM
"Our Second To None VPN Related Setup Case Study[/COLOR][/URL]
"One Stop Solution To Your Netgear VPN Connectivity"
*Visit the site for Non-VPN related Doc & Links* [Windows & Mac user/support]
June Mizoguchi-
Re: NGear CG3000D
We were talking about a static IP but Charter wants a business plan, I'm trying to work it out.
Only other way is each single line into the different rooms, = $$.
I have 65megs/mbps I guess it's called of service and they just dropped off the CG3000 tonight due to the UBEE router messing up. But, w/the UBEE router, we were OPEN and MODERATE, usually never strict. HUM.
If I get a switch (which one) and hook the X-boxes to that, then the PC's to the router after the switch, right? What will that do? Make it feed off the modem and not the router, right.
I did have a modem and then my NetGear Range router at one time, worked well, but then the X-boxes just arrived w/the kids from college, Smiley Happy
Maybe I need to go back to that set up.
So you are saying I need a IP for each Box and then for the house PC's/Wireless PC's,right?
Sorry if it's confusing, been at this most of the day.
Thanks again,
Jim
Luminary
Re: NGear CG3000D
3 public IP for xbox
1 public IP for the router
=4 public IP..
ANYTHING behind the switch will behind needs static IP (ISP/public IP) per shown diagram I made in this case. ALL the pc are BEHIND the router so they are PRIVATE IP that router is release NON routable IP so don't worry about it
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
Re: NGear CG3000D
Thank you.
Charter came out a few minutes ago and went into the router again. 192...RGServices etc. MOS for the user and disabled the firewall.
No change so they did talk about a modem/switch so we will see what they offer before I buy a switch.
Any recommendations on a good switch to buy?
Thanks again,
Jim
Luminary
Re: NGear CG3000D
not really. any 10/100 switch will be fine as long as your internet is lower than 100Mbps speed
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
Re: NGear CG3000D
Thank you.
One more question.
Will having the firewall disabled on the router hurt anything? Not sure if I like that Idea.
I know anytime a firewall is disabled it could have an effect. I do have protection on the PC's though.
Thanks again,
Jim
P.S. I did tell them that NetGear has routers for X-box etc. I can't remember where I saw it, but there was a list of like 8 different routers.
I mentioned it to the tech but we will see. I'm sure they won't go buy one just for me.
Luminary
Re: NGear CG3000D
If you are still suing CG for time being that I would turn the firewall back on Cdxx unit until you change whole setups
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
Re: NGear CG3000D
They left and left it OFF.
I know the user is MOS but can't remember the P-word he put in, it was changeme or something like that. He didn't tell me.
I guess I'll be alright.
Thanks again,
Jim
Luminary
Re: NGear CG3000D
You might able to rest the unit and may call comeback like it should be but you may want to call their support and just have them walk you through Smiley Happy
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
Re: NGear CG3000D
The tech dept only knows the admin password.
The Supt is supposed to call me back tomorrow. He called today and said they will continue to work on it. He has his IT dept working on a fix. I told them what you said about the switch etc, he agreed. I think that might be the next step. I will ask for a static IP but they only give that to business accounts. :confused:
Thanks again,
Jim
Luminary
Re: NGear CG3000D
well, I feel good that I did not suggest correctly.
keep update the info...
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
Re: NGear CG3000D
Yes you were right and I thank you very much.
I will pass on the updates and hopefully get it figured out.
Thanks again.
Jim
Luminary
Re: NGear CG3000D
hope they are given you a good deal to 4 public IP's... usually 10bucks per IP are common
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
Re: NGear CG3000D
Not sure on the IP's yet.
They are in the thinking stage.
I can set the X-Box to a specific IP in the range from what I have read to make it static. But not 100% sure how it works.
I might just get them to give me a modem and go buy my own NetGear Router. I had a NetGear Range router (lasted two yrs, burn't up) w/the extended warranty from Wally world Smiley Happy
What NG router would you recommend that has a good wireless signal and can be used for X-Box?
Thanks again,
Jim
Luminary
Re: NGear CG3000D
technically speaking any of N router that is out would work. There are bells and whistle on some models such as USB port with BOTH external HD and printer can be used and other models are only USB HD only.
but most part the are all the same. I think the pro/cons are issues that posted here in the forum so find the model you may interested and see if you find any issues you may want to be alerted.
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
Discussion Stats
  • 15 replies
  • 8309 views
  • 0 kudos
  • 2 in conversation
