Reply
Netgear router configuration
I feel as if I'm having a blonde moment - at first I assumed that configuration would be trivial... but, now, as I try to do so in practice - it's turning out to be much harder than I expected. Any hints tips/tricks welcome.
I've two rooms containing equipment - at opposite ends of a building. There's an 80mbit ethernet-over-mains link between them. In "location A", I've a Netgear DG834g - which acts as a NAT/firewall. Connected to this, by Ethernet, is a SmartTV, and an ethernet-over-mains adaptor. In "location B" there's a netgear router (which has been flashed with DD-WRT... for historic reasons.) Its uplink is connected to the second ethernet-over-mains adaptor... and there are further connections for a "desktop" and "server" designated PCs. The server runs minidlna - serving music and video.
Unsurprisingly, the SmartTV can't find the server - as, while they've all be configured to reside on the same subnet - the ADSL router assumes that all traffic that is not destined for a directly attached device is destined to be routed over ADSL... it is blissfully unaware that I've another LAN accessible from the second router.
My question: What's the cheapest/quickest/easiest way to solve this? (I'd prefer to stick to wired connections rather than try and connect the TV to the second router wirelessly...)
Luminary
Re: Netgear router configuration
setup 2nd unit a access point
http://kb.netgear.com/app/answers/detail/a_id/965
VPN Case Study
VPNCASESTUDY.COM
"Our Second To None VPN Related Setup Case Study[/COLOR][/URL]
"One Stop Solution To Your Netgear VPN Connectivity"
*Visit the site for Non-VPN related Doc & Links* [Windows & Mac user/support]
June Mizoguchi-
This is (almost exactly) the configuration I already have... the only difference is that my router and modem are a combined unit.
This configuration does allow me to access the internet from every port on both the modem/router and the access point. All the devices connected to the access point can communicate. Unfortunately, devices attached directly to the modem/router can't address my server attached to the access point.
The more I think about this, I suspect it is an inherent limitation of the Netgear DG834g adsl-modem/router... which routes everything to an address other that of directly attached devices to the internet.
I guess one strategy may involve port-mapping on the "access point" router - so my DLNA server appears to be present as a service on the router, as opposed to the server attached to it, and that should mean that other devices, like the "access point" router, directly attached to the modem/router should be able to see it.
Time to read some howtos. :-S
Luminary
Setup concept still same so combo unit will able to setup as AP
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
Discussion Stats
  • 3 replies
  • 2984 views
  • 0 kudos
  • 2 in conversation
