Reply
Novice
Troubleshooting help with frequent resetting of ADSL Modem
Modem: Netgear ADSL+Modem DM111PSP v2
Wireless Router: Netgear N600 Dual Band WNDR3400 v2
My modem is connected to the wireless router, and we use the following devices on the wifi network: Wii (primarily for Netflix), XBOX360, and 4 iphones.
My modem reboots itself frequently. (At least I consider it frequently)Smiley Tongue
I know it is probably normal for it to do this occasionally, but how often is considered too often?
I'd appreciate any help I can get with making sure that I have the appropriate and optimal settings for this product.
Thanks in advance!! Smiley Very Happy
Luminary
Re: Troubleshooting help with frequent resetting of ADSL Modem
start with hard reset the unit and see
VPN Case Study
VPNCASESTUDY.COM
"Our Second To None VPN Related Setup Case Study[/COLOR][/URL]
"One Stop Solution To Your Netgear VPN Connectivity"
*Visit the site for Non-VPN related Doc & Links* [Windows & Mac user/support]
June Mizoguchi-
Novice
I have already tried a hard reset.
Luminary
replace dsl filter .
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
Novice
OK, it is done, I will let you know. Thank you for helping me out with this! Smiley Happy
Discussion Stats
  • 4 replies
  • 11035 views
  • 0 kudos
  • 2 in conversation
