Reply
Follower
can't connect to internet thru CG3000D cable modem
I got CG3000D used cable modem, called my cable provider-Time Warner, gave them MAC address. They said it is registered and activated so I rebooted the modem see the lights blinking to solid green indicating it is connected.
They say they are able to communicate with my modem however I can't get onto internet wired or wireless.
When I connect my PC to one of the ethernet port, it is orange light and I get no connection. I tried to open wireless network, connected to wireless net, but still no internet connection.
Is there a special trick to get this modem/router working?
Thanks in advance.
Luminary
Re: can't connect to internet thru CG3000D cable modem
CGxx modem is usually for broadband provided units and not retail which means all support must come from your ISP
I would get replaced with your ISP
VPN Case Study
VPNCASESTUDY.COM
"Our Second To None VPN Related Setup Case Study[/COLOR][/URL]
"One Stop Solution To Your Netgear VPN Connectivity"
*Visit the site for Non-VPN related Doc & Links* [Windows & Mac user/support]
June Mizoguchi-
Discussion Stats
  • 1 reply
  • 4386 views
  • 0 kudos
  • 2 in conversation
