Reply
enable usb port on CG3000
i just got a Netgear CG3000 router from the company i got internet at.
The problem for me is that they somehow disabled the usb port thats on the router.
Do you guys now if it´s possible to enable it somehow again ? ( i tried looking in the admin interface no luck there. )
Re: enable usb port on CG3000
Do you have the privelege to login to its configuration page?
kat
I'm wondering if I could help you.
by configuration page do you mean where i set up the wireless and so on ?
Yes, like by typing its IP address on the browser http://192.168.0.x for example. Are you able to get in? Are you able to get a Netgear Smart Wizard page or a custom page from the internet service provider?
kat
i can get in on 192.168.0.1
and when i get in i have these options
Add WPS Client
Setup
Basic Settings
Wireless Settings
Wi-Fi Multimedia
Mta Status
Content
Filtering ( in the admin interface content and filtering is below eacher other. )
Logs
Block Sites
Services
Maintenance
Modem Status
Connection
Set Password
Backup
Event Log
Diagnostics
Advanced
Reset
Wireless Settings
MAC Filtering
DynamicDNS
Port Blocking
Port Forwarding
Port Triggering
DMZ Host
LAN IP
Remote Management
UPnP
NAT
Luminary
don't waste too much time. ISP provided unit may have branded firmware where it may disabled or cripple it.
call ISP and ask this issue
VPN Case Study
VPNCASESTUDY.COM
"Our Second To None VPN Related Setup Case Study[/COLOR][/URL]
"One Stop Solution To Your Netgear VPN Connectivity"
*Visit the site for Non-VPN related Doc & Links* [Windows & Mac user/support]
June Mizoguchi-
do you guys know if that usb port on the CG3000 can be used to plugin a lets say usb harddrive ? if it worked like it should
Luminary
it's for USB HD
again , CALL ISP
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
i talked to them. it´s disabled from them because then dont wanna support if people get trouble using it.
Do you guys know if it´s possible to some how put another firmware on it ?
Luminary
Branded firmware is ther to work with their network .
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
Hi , i know this is an old post , but i still want to reply to it... because there has not been an answer to the question..
im having same problem, where isp has locked out the usb but wont give the possiblity to open it for usage, because they dont want to give support to it..
but i my case where i work with computers everyday, i dont need support. what i need is a way to FLASH the router to original state.
Luminary
Go to support.Netgear.com and search open source
If you can not compile source then I say you are out of luck anyway
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
Novice
I have the same problem but with a different situation. I understand that ISP's lock the USB port on their routers. So, I went out and bought my own brand new router, a NetGear CG3000D (not someone's old ISP router). It is running software V5.5.2RG-05B and hardware 2.01. I cannot even see the USB as a list item in the router configuration screen. How do I turn the USB port on, and how do I see it on the configuration screen?
Luminary
Your best bet is to ask directly to support on this.. my.netgear.com portal
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
OK folks, as a Consulting Engineer who's expertise lies in this area, please let me address this, and hopefully eliminate all the FUD in this thread.
Let's start with the first basic premise: A DOCSIS Wireless Cable Gateway is NOT a Wireless Router with a Cable Modem added. It is a unified embedded DOCSIS Converged CPE design, with the fundamental SoC solution being a DOCSIS device....in other words, if anything, you can think of it as a CABLE MODEM with a Wireless Router functionality added to it.
The distinction above is important.
DOCSIS Gateways essentially have two possible chipset/Reference designs available in the marketplace....Broadcom based or Ti (Intel) based. Current (2012/early 2013) Broadcom based Cable Gateways use a proprietary operating system called eCOS. Ti (Intel) based Gateways use Linux.
The reason that the USB port does not have any Software function on the CG3000Dv1 NETGEAR Cable Gateway is because it is Broadcom eCOS based, and there is no easy way to add Software drivers or application support on Broadcom's proprietary eCOS Operating System. It is as simple as that. On previous/current (2012/early 2013) Broadcom based Cable Gateways like NETGEAR's CG3000D(v1), the USB host port is simply a "USB Charging port" due to this limitation. I don't know why Broadcom did not follow-thru with releasing the necessary API's to support advanced SW function for the USB port...but they didn't. So the marketplace is stuck with BCM3380 Gateway devices where the USB port ends up being simply a port to charge from.
Future generation Broadcom DOCSIS Reference designs (late 2013/BCM3383 or newer based) have the capability for the manufacturer to introduce a new Linux thread (in combination with the Broadcom eCOS OS). These designs will allow USB host port functionality for things like Printer and USB drive support. These new Broadcom BCM3383 designs are just becoming available in the marketplace, and NETGEAR has a few that have recently been released (CG3000Dv2 and CG4500BD).
I can tell you 100% that what I've written above is accurate, as I've been intimately involved with DOCSIS CPE products in the North American industry for over 12 years now... (essentially since DOCSIS was invented). This is my bread & butter, so I know whereof I speak.
So please don't blame the manufacturer or the ISP for limited USB support on previous generation Cable Gateways...it "is what it is", and there will not be any kind of support on previous gen (BCM3380) Gateways (beyond ancillary device charging...)
DOCSISMan
Luminary
Good one.. thanks for it
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
Re: enable usb port on CG3000Dv2
I have the latest modem CG3000Dv2, and still not able to use the USB drive, via front or back USB ports.
I have contacted ISP and Netgear AU but have not been able to use the USB function. Please help.
DOCSISMan
Luminary
CG3xxx models falls in to Provider Products
http://www.netgear.com/service-providers/products/cable/gateways/cg3000-cg3100.aspx#tab-techspecs
Products falls in to Provider section are mostly branded firmware and not stock firmware so you can expect that certain feature is not enable/ available due to the ISP branded firmware.
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
Luminary
Here is some for you guys to read on CGxxx
http://kb.netgear.com/app/answers/detail/a_id/24693
Overview:
This article will help explain how to connect and access a USB device that is plugged into the N450.
Please note that the N450 does not have full Readyshare feature on this FW version.
Symptoms:
want to view and access content on my USB drive connected to the N450
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
Discussion Stats
  • 18 replies
  • 43463 views
  • 0 kudos
  • 7 in conversation
