Reply
PTV2000 - how to update firmware?
From what I understand here, there is a 2.1.x.x-firmware for the PTV2000.
But how do I update the firmware for this? I see for some earlier versions of the WiDi-software, there should be a "update firmware"-choice, but can't find anything now. The software just state that my software (2.0.33.0) is up to date.
Maybe it is... at the moment I get lag when playing video, and disconnection between pc and PTV2000 quite often. I'm using a Lenovo Thinkpad T420s with Core i7 and Wi-Fi Link 6300.
Luminary
Re: PTV2000 - how to update firmware?
http://support.netgear.com/app/answers/detail/a_id/19374
might just download manually and follow the how to in the link
VPN Case Study
VPNCASESTUDY.COM
"Our Second To None VPN Related Setup Case Study[/COLOR][/URL]
"One Stop Solution To Your Netgear VPN Connectivity"
*Visit the site for Non-VPN related Doc & Links* [Windows & Mac user/support]
June Mizoguchi-
Ain't that just the connectionsoftware? The version I downloaded from Intels site is newer than the one you linked to. Is the firmware a integrated part of Intels software?
Luminary
that I could not comments. I would think just as software app for intel you should able to but it could still have compatibility with devices.
I will let some one answer this or ask support at my.netgear.com
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
Discussion Stats
  • 3 replies
  • 15773 views
  • 0 kudos
  • 2 in conversation
