Reply
Novice
Anyone else having issues with Apple IOS 7 and WIFI connection?
I am about to pull my hair out. I have WNDR3700v2 with firmware version V1.0.0.32. My 2.4GHz has WPA2-PSK [AES] security and I can not get my daughters Ipod Touch 5th Generation to connect to our wifi. Everything else we connect wirelessly with works just fine, including a 4th generation Ipod Touch.
I checked Apple's website and made sure all of the settings that they suggest;http://support.apple.com/kb/HT4199. I even renamed and changed the password for our 2.4GHz wifi. At first I was thinking it was an IOS 7 issue, except that the Ipod Touch connects just fine with all our friend's wifi. Now I am starting to wonder if it is an issue with my router.
Has anyone else had to deal with this problem? Am I missing something obvious. I am not totally fluent in routers, but our router has been working without issues until now.
Mike
Luminary
Re: Anyone else having issues with Apple IOS 7 and WIFI connection?
Try pushing the small "i"-icon to the right of the network name when you're in Settings -> Wi-Fi and then choose "Forget this network". Does it help?
Have you tried connecting to the 5 GHz network on the 5th gen iPod, does that work?
What exactly happens when you try to connect to the 2.4 GHz network on that iPod, does it just say "Could not connect to..." or something else?
8/1 Mbit/s ADSL
Router: D-Link DIR-615
Wired AP: Netgear WNR1000v2
Novice
There is no network information when I click on the "I". My 2.4GHz family and guest networks show up black under "Choose a network". When I try to connect to either of them it just says "unable to join the network". I haven't tried connecting to my 5GHz, but I'll give it a try at noon and let you know.
Early on in my quest (2 months ago) I did even restart my router and modem, with all my gadgets off, and then went through and turned each one on.....with no luck. This problem has been on my "back burner" of things to do, but now that I have the time and want to get this puzzle figured out.
Luminary
Use quote wisely
http://forum1.netgear.com/showthread.php?t=56314
VPN Case Study
VPNCASESTUDY.COM
"Our Second To None VPN Related Setup Case Study[/COLOR][/URL]
"One Stop Solution To Your Netgear VPN Connectivity"
*Visit the site for Non-VPN related Doc & Links* [Windows & Mac user/support]
June Mizoguchi-
Luminary
In iPod go to settings and Wifi. You will find "i" with circle on right next to SSID of your network name. On the next page you will find IP information and and top or bottom you will see "forget this network"
I would suggest to hard reset the router
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
Retired_Member
Check for IP Conflict
Novice
jmizoguchi - sorry for the quotes. I'm still learning the ins and outs of forums.
When I click that "I"-icon there is no network information showing up and no link to forget the network. I have gone through the "settings-general-reset" and reset the network settings to no avail.
I seen the hard reset link on your signature. I'll back up my configuration and give that a try. I'll post back on how that goes.
WizardJ - I tried the 5GHz network and that doesn't even show up on the Ipod.
Luminary
Settings-wifi
Look at SSID name and there is "I"
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
Novice
We are on the same page. What I am saying is that there is no information under the "I"-icon. IP address, subnet mask, router, dns, search domain and client ID are all empty fields. I am assuming that I would have had to connect to my wifi, at some point, in order for that information to appear. I assume I would then see the Forget Network selection on this screen too.
I am going to do the hard reset and start my configuration from scratch this afternoon. The hardest part is trying to find a time when the family doesn't need wifi. One thing I don't want to do is screw it up so that we have no access for any of our devices. I know that is probably hard to do, but I'm sure I would find a way.Smiley Happy
Virtuoso
jmizoguchi wrote:
Use quote wisely
June, you and others have been asked not to quote that sticky thread, that's not what it's for and it's not your job to try and back-seat moderate the forums this way. Do not continue to post comments relating to posts/threads being duplicated, in the wrong forum, or poor use of quoting, if you do so we will start issuing infractions against you.
Luminary
I see. Seems like nothing gotten released at all... strange
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
Novice
June,
My problem is solved! Thanks for your help. I did the 20-20-20 hard reset and renamed my networks and the Ipod Touch is working beautifully. My daughter will be happy when she wakes up tomorrow.
Mike
Luminary
Sound great!
Enjoy
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
I'm having that issue too! although it's on IOS 8
NETGEAR Moderator
hi @Devisevib,
Did you do all those steps that they discussed? You have the latest 8.4 IOS? Same model & version of router too? Same result when trying to connect on both frequencies (2.4Ghz/5Ghz)?
ElaineM
Community Team
Discussion Stats
  • 14 replies
  • 13602 views
  • 0 kudos
  • 7 in conversation
Top Contributors
