× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
Can't edit QoS policy on R6050 router
something
Follower
I'm trying to change the QoS priority of one of my devices connected to my router, but when I select the device from the QoS Priority Rule list and click the edit button I get a generic browser error message. I've tried it on multiple devices and using different web browsers but I just get different error messages. On Firefox I get "The connection was reset", on Edge I get "Hmm... cannot reach this page", and on Chrome I get "routerlogin.com didn't send any data". No matter what MAC address whose policy I try to edit I get these errors, but if I manually add a priority rule then I can edit it freely. I'm running Windows 10 and both my OS and the router are fully updated. What can I do to update my device's QoS priority?
Model: R6050|A750 Wireless Dual Band Gigabit Router
Message 1 of 3
Accepted Solutions
DexterJB
NETGEAR Moderator
Re: Can't edit QoS policy on R6050 router
Hi @something,
1. What is the firmware version of the router?
2. Have you tried resetting the router?
3. If the issue persists, you can try re-flashing the firmware then do a factory reset.
Dexter
Community Team
Message 2 of 3
All Replies
DexterJB
NETGEAR Moderator
Hi @something,
Dexter
Community Team
Message 2 of 3
DexterJB
NETGEAR Moderator
Hi @something,
I would like to follow up and check if you are still experiencing the issue.
Dexter
Community Team
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 2921 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
