× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
How do I change the default username on WNDR3700v5
CharlesNovel
Tutor
Hello, I found how to change the administration password on my router, but I would also like to change admin by something else.
I have been looking for a while and was unable to find anywhere how to replace 'admin' by something else.
I would love any answer, including it is impossible, so I will stop to search Smiley Wink
Kind Regard, CharlesNovel
Model: WNDR3700v5|N600 WiFi Dual Band Gigabit Router
Message 1 of 4
Accepted Solutions
CharlesNovel
Tutor
Re: How do I change the default username on WNDR3700v5
Hello again, I just found that it is not possible... so I would strongly recommend that a line saying it would be added in the manual... that will save time to people like me! (and I do not seems to be the only one Smiley Frustrated
Message 3 of 4
All Replies
netwrks
Master
You can only change the pw, not the userid. That way with all NG routers..
Message 2 of 4
CharlesNovel
Tutor
Message 3 of 4
CharlesNovel
Tutor
thank you very much, CharlesNovel
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 5786 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 7
