MWJR's avatar
MWJR
Follower
Mar 28, 2018
NETGEAR AC1900 WiFi Modem Model C6300BD
I bought a ROKU yesterday, and am unable to connect to internet, because I don't know the password.  I have had the router for 2 years, and don't even remember having to use a password to hook it up, and have never been asked for a password.  I don't know what to do.  I tried using the default on the bottom side of the router, but that does not work for me.  I don't know what to do next.  Any suggestions as to how I can solve this problem?  Thanks.
    Is that the wifi password or the password for the router interface? They aren't the same.
    There is a manual for the C6300 somewhere at the end of this link:
    >>>> C6300 | Product | Support | NETGEAR <<<<
    It is hard to say any more without knowing what you are doing and where it goes wrong.
1 Reply
  • michaelkenward's avatar
    michaelkenward
