× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
READYSHARE not recognizing USB
did123445
I unpluged my usb device to add some data, after re-pluging it, my router wont recognize it! I have tried to reboot the router, erase files from the drive, but no luck at all... what may i do in this case!
Model: WNDR4500v3|N900 WIRELESS DUAL BAND GIGABIT ROUTER
Message 1 of 4
Accepted Solutions
did123445
Re: READYSHARE not recognizing USB
ok so after quite a while, the router recognized it and added it as normal... seems you have to be very patient...
Message 2 of 4
All Replies
did123445
Message 2 of 4
crappy
will not turn on usb lite...any of software results wonr work...is router defective...printer works to computer but router will not recognize printer
Message 3 of 4
ElaineM
NETGEAR Employee Retired
@crappy Are you using the same model number of router?
Did you try other computer? Make sure to turn off firewall on your computer.
ReadySHARE printer set up instructions
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 10740 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
