- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
ReadyShare can't find USB drive
- Mark as New
- Bookmark
- Subscribe
- Permalink
Have 2 laptops connected to Readyshare. Been working OK.
One laptop had a hard drive die, so I replaced and reloaded win10.
The bad drive would still let me get files off of it, so I didn't use ReadyShare
After reinstalling everything, both computers can't connect to ReadyShare
Simply won't recogize there is a drive attached.
Attached drive has its blue light blinking, so I know it's alive.
Any ideas on how to fix?
BTW the new version of Genie is so slow it is painful to use.
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
OK, Found the solution.
Uninstall the latest version of Genie. It is junkware.
Reinstall the pervious version. All is good.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: ReadyShare can't find USB drive
What Genie version were you using previously and what version that made it worked?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Your software does not display version numbers, so I have no idea.
My admin interface suggested updating to the newest version, and that's when the trouble began.
I found a 2.428.0 Genie version from 2016 in one of my folders. Maybe that is the one I went back to.
