- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
VPN doesn't establish client-to-gateway tunnel | no VPN for Internet browsing
- Mark as New
- Bookmark
- Subscribe
- Permalink
I bought Netgear WNR614 WiFi router 6 months back. I'm facing a strange issue with this router.
Router doesn't allow to establish VPN tunnel through it (from my home to company's VPN gateway).
I get IPv4 Public IP from ISP. If I connect the uplink to my laptop directly, I'm able to establish VPN session.
I don't have provision to disable Firewall in the router webpage.
Router Firmware Version: V1.1.0.32_1.0.1
I'm using Windows7 os in my laptop.
Any help to resolve this issue would be appreciated.
Thanks,
Shyam.
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Welcome to the community, @Shyam6784
The router is capable of VPN Passthrough. Check the link below.
Troubleshooting VPN passthrough for home routers
You may also want to see page 26 of the manual.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: VPN doesn't establish client-to-gateway tunnel | no VPN for Internet browsing
Thanks ElaineM,
After adding Port Forwarding records for ports 500 and 1701-1723, I'm able to establish VPN tunnel through the router.
Shyam
- Mark as New
- Bookmark
- Subscribe
- Permalink
That's good news! Thank you for the update.
