Reply
WNDR3700v3 Not port Forwarding
Hi! I have my 2nd PC wired to my WNDR3700v3, but the port forwarding is not working. I put in the proper port and IP address of my PC, but the port is still closed.
How can I fix this? It's preventing me from enjoying a bunch of my software.
Luminary
Re: WNDR3700v3 Not port Forwarding
Make sure that WAN/Internet port of the router has public IP ( ISP released ip)
VPN Case Study
VPNCASESTUDY.COM
"Our Second To None VPN Related Setup Case Study[/COLOR][/URL]
"One Stop Solution To Your Netgear VPN Connectivity"
*Visit the site for Non-VPN related Doc & Links* [Windows & Mac user/support]
June Mizoguchi-
How can I find out what my public IP is? Im a bit new to home networking.
Luminary
Under router status in the router GUI
As long it is not 192.x or 10.x ip then you should have public ip
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
Virtuoso
Here's how you do port forwarding :
http://kb.netgear.com/app/answers/detail/a_id/24046
If still doesnt work try to connect your computer to the modem and check the ports are still closed. If its closed then better contact ISP to open it.
Discussion Stats
  • 4 replies
  • 7961 views
  • 0 kudos
  • 3 in conversation
Top Contributors
