× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
WNDR4300 Connection is not private, certificate authority invalid
psky
When we try to connect to the internet with our cells, tablet, laptop, we get;
"Your connection is not private", NET::ERR_CERT_AUTHORITY_INVALID.
Called my internet provider who troubleshooted over the phone, then sent a tech out. After troubleshooting, tech says its strange that 2 MAC addresses come back whenever I try connecting just one device, when only one address should be coming back. Tech said the router is bad and needs replaced. The router is only 4 months old. Anyone heard of this issue?
Model: WNDR4300|N750 Wireless Dual Band Gigabit Router
Message 1 of 4
Accepted Solutions
psky
Re: WNDR4300 Connection is not private, certificate authority invalid
Factory reset worked! You saved me from having to buy a new router, thanks.
Message 3 of 4
All Replies
ElaineM
NETGEAR Employee Retired
Welcome to the community, @psky
Did you try using a different browser?
Which browser are you using?
Have you also tried doing a factory reset on the router?
After resetting the router, reconfigure it as if it's brand new out of the box then check for your connection.
Message 2 of 4
psky
Message 3 of 4
ElaineM
You're welcome. Glad to hear that it's up and running!
Have a great day!
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 4466 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
