Reply
WNDR4500 - Corrupted firmware
[ Edited ]
My WNDR4500 has had corrupted firmware twice in the last month. I've had no power outages or any obvious reason for this to occur. (And of course I lost my installation CD) I was able to manually reinstall the firmware, but it's kind of a pain. Anyone have any guesses on why this might be happening? I also wish I could download the firmware recovery tool from Netgear, but it's not available...TIA
Luminary
Re: WNDR4500 - Corrupted firmware
contact support for your issues at my.netgear.com
you probably either downloaded corrupted firmware is likely over actual firmware is corrupted
VPN Case Study
VPNCASESTUDY.COM
"Our Second To None VPN Related Setup Case Study[/COLOR][/URL]
"One Stop Solution To Your Netgear VPN Connectivity"
*Visit the site for Non-VPN related Doc & Links* [Windows & Mac user/support]
June Mizoguchi-
this site worked wonders for me after i got my product with a blinking green light.
http://kb.netgear.com/app/answers/detail/a_id/18989/kw/wndr4500%20corrupted%20firmware%20recovery%20...
i followed that step by step but after the eneter cmd into the start menu thats where i get lost cause ill put cd then hit enter and i cant navigate through anything to find the firmware file it needs more detail way more
ok. to make it simple you should extract the rar file with the firmware updat in it and just put it in your C: folder. So when you go into CMD
you can find it easier. now when you open it...it sill say c:windows/system32. type CD.. and hit enter....now it will say C:windows. Type CD.. and hit enter again and you should be at the root menu of C: At this point type DIR to pull up the list of whats on the root directory. you should see your folder. For example....Mine was WNDR4500-v1.0.1.18_1.0.36. So when you go to enter you folder type CD WNDR4500-v1.0.1.18_1.0.36 (type yours if different) and hit enter. Now you will be in the folder you created. and hit DIR again to see the file. FYI..don't change the firmware file name at all when you put it in the folder on your C drive. next you will see C: (yourfoldername) type tftp -i 192.168.1.1 put wndr4500-v1.0.1.18_1.0.36.chk and hit enter (yes the spaces are supposed to be there). it will send it to the router....now watch your lights and don't do anything until the power light turns solid green. your wireless lights will probably blink blue before that tho. When the power light is solid green....then unplug the power, count to 10, plug it back in and after 2 min u should have all the lights the way they used to be. I hope this helps!
Also if it says "tftp" is invalid or something along those lines. then go into start, in the search bar type "programs and features" and then click "turn windows features on or off" and check the TFTP client to enable it. then try the command under CMD again and you should be golden Smiley Happy
Luminary
see router reset on my sig below and click on router upgrades.
you do not have to use command line which are related to TFTP method. for most user just need to follow via router GUI to uploaded
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
when the power light blinks. Sometimes it disables the access to the GUI for doing an upgrade. TFTP is the only way to fix it if that is the case. I was on the phone with NG tech support for 2 hours trying to resovle that issue when I first got my router, and they didn't know how to do anything aside from having me return my product for exchange. This method that I posted took 5minutes and workded flawlessly when my GUI was unobtainable. The internet is much better then tech support these days.
Novice
This happened to me today too. I had upgraded to v1.0.1.18_1.0.36 a few weeks back through the router GUI. Everything had been working just fine. Today we had a thunderstorm and lost power for about an hour (no lightning strikes anywhere in audible distance when the power went out). When power came back, to make a long story short, the power light was blinking green indicating corrupted firmware. Luckily, my VoIP adapter can act as a router too, so I put that in as the primary and was able to get online to look for help here. The tftp dance with the firmware image fixed it.
So the big question is, why did this happen? Is this normal for Netgear routers? I've only had my WNDR4500 since May. I had Linksys routers for more than 10 years and they never "corrupted themselves" when the power went out. This was a huge pain for me. I work at home, so I lost a few hours in addition to the power outage trying to recover.
Yes. Ppl need to use power surge protection or apc power bricks to avoid anythng from corrupting. But yes. Netgear is notorious for corrupted hardware after an outage if not plugged into proper protection.
Luminary
Surge strips will not help an issues .
Backup UPS is need to prolong the devices and prevent from an issues.
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
Novice
Good to know it is not an unheard of thing for this to happen , if not disappointing. I feel sorry for people that aren't tech saavy .
Mine is plugged into a surge protected power strip. After this, I think its time to get a new UPS anyway.
You're right! a power strip won't work, but a surge protector will. And an APC backup as stated before will also work and is the best solution for any pc related product. and since a power surge is the cause for it. Surge protector is the first line of defence.
Luminary
Surge protector only protects spikes only
UPS protects burnout which is most important thans spikes. Off course UPS protect all conditions.
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
And the spikes are what cause the router to corrupt. So where is the issue with that? For someone who can't afford a apc battery back up. Surge protector will be a good first line of defence.
Luminary
Good surge protector cost $25 bucks some and UPS you can around 45bucks
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
Novice
My strip is supposed to be surge protected. Didn't help obviously. Tax free weekend here, so good time to pick up a new UPS.
I did all of this. I now have a solid green power light but still no connectivity. Netgear genie gives me this message:
The router Internet port has no connection or the connection is loose, or the connection settings are not configured properly.
Opening router configuration for you to check. The user name is admin. The default password is password.
Please help!
Luminary
Please help!
refer to manual how to login the router and check all your settings
support.netgear.com and download manual
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
ok. to make it simple you should extract the rar file with the firmware update in it and just put it in your C: folder. So when you go into CMD
you can find it easier. now when you open it...it sill say c:windows/system32. type CD.. and hit enter....now it will say C:windows. Type CD.. and hit enter again and you should be at the root menu of C: At this point type DIR to pull up the list of whats on the root directory. you should see your folder. For example....Mine was WNDR4500-v1.0.1.18_1.0.36. So when you go to enter you folder type CD WNDR4500-v1.0.1.18_1.0.36 (type yours if different) and hit enter. Now you will be in the folder you created. and hit DIR again to see the file. FYI..don't change the firmware file name at all when you put it in the folder on your C drive. next you will see C: (yourfoldername) type tftp -i 192.168.1.1 put wndr4500-v1.0.1.18_1.0.36.chk and hit enter (yes the spaces are supposed to be there). it will send it to the router....now watch your lights and don't do anything until the power light turns solid green. Smiley Happy
I am able to get this far but after I hit 'enter' in just about one minute I get the error msg: timeout occurred connect request failed. I've tried this over and over again and always get this message. What can I do now? BTY when I type in CD I always get \users\Patsy so that is where I have the file.
Luminary
you have to type cd..
until you get c:\ or
cd desktop if you save a file on desktop
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
I also cannot ping the router using the ip address I put in TCP.
When I type in cd it does not change. Still \users\Patsy.
Luminary
Here is clear view on how tftp works and firmware should be in C:\
if does not respond to ping and unit and unit is under warranty, have support exchange on RMA
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
Luminary
you have to cd.. hit enter. and again and again till you get c:\
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
Thanks, it is under warranty. I've had it less than two months and I registered it when I bought it.
Discussion Stats
  • 32 replies
  • 59359 views
  • 0 kudos
  • 14 in conversation
