× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
WNDR4500v2 E-Mail port number
Bengt7jqb
How can I define the port number?
Cant find a spot to use here
Model: WNDR4500v2|N900 Wireless Dual Band Gigabit Router
Message 1 of 15
Accepted Solutions
ElaineM
NETGEAR Employee Retired
Re: WNDR4500v2 E-Mail port number
The model has been considered EOL for awhile now and there will be no future firmware enhancements that will be released.
Message 12 of 15
All Replies
What are you trying to do? Set up email alerts?
There is a manual for the WNDR4500v2 somewhere at the end of this link:
>>> WNDR4500v2 | Product | Support | NETGEAR <<<
See page 74.
Message 2 of 15
Bengt7jqb
I need to specify port number too, 587 for this one
Is it posible? Or it comes in next update?
Message 3 of 15
If it isn't available already, that isn't the sort of thing that new firmware is likely to add.
On my device it is in:
  • Advanced
  • Security
  • Email
Message 4 of 15
antinode
Guru
   Can't (yet) see the picture.  A plain-text description might appear
sooner.
   I know nothing about these routers' e-mail capabilities, but a
standard notation would be "<name_or_address>:<port>".  Adding ":587" to
the Mail Server name/address should be an easy experiment to run.
Message 5 of 15
Bengt7jqb
But there are no space for port number
Message 6 of 15
antinode
Guru
> sooner.
   Still true.
   Huh?  Is there a place to put the Mail Server name/address?  Can you
add ":587" to what you have there now?  It's not complicated.
Message 7 of 15
Bengt7jqb
No  I try pop.server.com:587 and its not a good e-mail
It seems not posibal
Mybe it try to send on 25 and this is blocked
Message 8 of 15
Bengt7jqb
You can be shure I red all the manual, I cant still not let ot post on port 587
See page 74.
I have red it all
 This does not work
And tis does not work
Message 9 of 15
ElaineM
Unfortunately, you cannot specify a port on this model.
Message 10 of 15
Bengt7jqb
Mybe its time to include it in next update then
Message 11 of 15
ElaineM
Message 12 of 15
Any chance that you can find one of those free email services that can use the device's native settings and then forward the messages to your existing email?
Maybe something like Google would work.
Message 13 of 15
Bengt7jqb
No, Port 25 is blocker for me by my ISP
Message 14 of 15
Bummer.
Message 15 of 15
Top Contributors
Discussion stats
  • 14 replies
  • 2237 views
  • 1 kudo
  • 4 in conversation
Announcements
Orbi WiFi 7
