Reply
Novice
WNR1000v2 Force firmware to router
I have a WNR1000v2 router that was given to me by Comcast and I was always under the impression that it has the normal Netgear firmware on it. I then found out this was not true. It turns out it has firmware: V1.0.0.12NA and is showing as hardware version: WNR1000v2-VC. I found out that the "VC" on the end means it is custom firmware from Comcast. This displeases me a lot. I am having issues with the wireless dropping and router resetting and such. I wanted to put the normal stock firmware on this router instead. I know it is possible to fix bricked routers by forcing it to accept firmware with tftp and was wondering if anyone has any ideas on how I can force it to accept the newest stock Netgear firmware for the WNR1000v2 router. When I try it on the Web GUI it fails and wont accept it.
Oh and BTW, to all those that have this router. Comcast has informed me that the router is no longer theirs. It now belongs to me and that as of 11/28/12 they stopped providing these free routers and I can do with it as I please and they do not offer any type of support.
Luminary
Re: WNR1000v2 Force firmware to router
tftp method
http://forum1.netgear.com/showthread.php?t=30453
VPN Case Study
VPNCASESTUDY.COM
"Our Second To None VPN Related Setup Case Study[/COLOR][/URL]
"One Stop Solution To Your Netgear VPN Connectivity"
*Visit the site for Non-VPN related Doc & Links* [Windows & Mac user/support]
June Mizoguchi-
Novice
ok. I will give it a shot. Funny thing. I think it was you I was talking to before on here and I was telling you how I work for Comcast and the firmware is not modified and upon looking at my router more since I started having problems I can confirm it is custom firmware. they removed some things in this firmware. I was surprised.
Novice
no such luck. I was able to downgrade to earlier version
Apprentice
So... it was successful in downgrading to a Netgear version of firmware?
Novice
no it downgraded to an earlier version of the modified firmware
Apprentice
Have you gone to the Netgear website and download the Netgear firmware and attempt to upgrade it???
Novice
There is new firmware for that router:
Go to this page:
http://downloadcenter.netgear.com/en/product/WNR1000-2VCNAS
WNR1000-2VCNAS Firmware Version 1.2.2.56
Enhancements and Bug Fixes:
Added support for IPv6.
Fixed a number of IPv6 related compatibility issues.
Support various HNAP commands to work with iControl solution.
Support for HNAP calls to change region and wi-Fi settings through iControl solution.
Fixed a number of GUI bugs.
Installation Instructions:
Download the file to a convenient place such as your desktop.
Note: Do not upgrade the firmware using a wireless connection. Please perform firmware upgrade with “wired” or Ethernet connection only.
Open a Web browser.
Access the router (http://192.168.1.1 or the Default Gateway address if the router's default IP was changed).
Log in the router (User Name = admin and Password = password, unless you changed it).
Write down all settings that you entered when previously configuring. This includes information such as ISP configuration and wireless security settings.
Under Maintenance, click Router Upgrade.
Click Browse and locate the firmware upgrade file.
Click Upload.
Wait for the router to reboot.
Under Maintenance, click Settings Backup, then click Erase. (Or press the reset button on the back for 10 seconds.)
Wait one minute for the router to reboot.
Manually enter the configuration information you wrote down in Step 5.
Luminary
Tftp is you want to change firmware in branded unit
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
Is there a way to modify the comcast router to a normal stock netgear router
i mean the firmware..
Luminary
already answered
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
No go on my end
I do see the "boot wait" period when it shortly responds for ping for about 5 seconds; then it stops and it starts again in about 4-5 seconds when the image has booted.
So that tells me that the boot_wait does expect a tftp but for some reason it doesn't accept the transfer. My tftp always times out.
Is there a way to open up that box and get a serial console going so that one can ensure boot_wait is set?
Or even better is there a way to hook a jtag cable and upload the binary image straight into the flash that way? What software would one use for the WNR jtag implementation?
Discussion Stats
  • 11 replies
  • 15584 views
  • 0 kudos
  • 6 in conversation
Top Contributors
