Reply
WNR2000 V3 port forwarding
f/w V1.1.2.6
has been working great, until I tried to connect 2 LG brand LW130W HD IP wireless/wired cameras.
Cannot get NAT/port forwarding to work.
The camera has two ports, the web port 80 and RTSP (real time streaming port) port 554.
on the camera 192.168.1.14 is for its wired IP.
WNR2000 has static public IP on the WAN side.
Block services: never
Port forwarding setup for web port:
Service Name: camera1-http
Protocol: tcp/udp
External Starting Port: 8014
External Ending Port: 8014
Internal Starting Port: 80
Internal Ending Port: 80
Internal IP address: 192.168.1.14
Port forwarding for RTSP port
Service Name: camera1-rtsp
Protocol: tcp/udp
External Starting Port: 8554
External Ending Port: 8554
Internal Starting Port: 554
Internal Ending Port: 554
reboot WNR2000
nmap from a remote public IP gives:
Host is up (0.045s latency).
Not shown: 999 filtered ports
PORT STATE SERVICE VERSION
8080/tcp open http uhttpd 1.0.0 (Netgear wnr2000v3 WAP http config)
|_html-title: 401 Authorization
| http-auth: HTTP Service requires authentication
|_ Auth type: Basic, realm = NETGEAR wnr2000v3
Thanks
Len
Luminary
Re: WNR2000 V3 port forwarding
Do you have public IP in WAN of router?
Sounds like you do...
VPN Case Study
VPNCASESTUDY.COM
"Our Second To None VPN Related Setup Case Study[/COLOR][/URL]
"One Stop Solution To Your Netgear VPN Connectivity"
*Visit the site for Non-VPN related Doc & Links* [Windows & Mac user/support]
June Mizoguchi-
yes, not in the cable modem, but in the WNR2000 WAN side
Luminary
Then is should work
Make sure you are testing outside of your network
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
I also have Q-See network video recorder, NVR.
It's IP is 192.168.1.120
web port 3730
media port 9000
I set up port forwarding like above with :3730 LAN side and :3730.
nmap from external IP shows:
9000/tcp open tcpwrapped
I don't have access right now to a browser machine outside my network, but as I said, nmap (network mapper) shows only remote router admin port 8080 open, so I don't how a browser outside my network would fine the IP camera web/rtsp ports open.
Len
Luminary
Testing behind the router will be loop back so you need to outside of you network to test or use smartphone and use cell data to test it
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
Novice
I am hooking up a NetGEar wnr2000v3 to a security system and trying to set up to view on an iphone.
so far I have succeeded in accomplishing this:
TYPE STATIC
MEDIA PORT: 18004
WEB PORT: 00080
IP ADDRESS: 192.168.001.203
SUBNET MASK: 255.255.255.000
GATEWAY: 192.168.001.001
DNS: 066.169.062.073
Port checker says SUCCESS on both ports but I cant figure out how to view online. when I put my IP address( 66.169.62.73) in the IE window and put :00080 nothing happens
what am i doing wrong or need to do right?
Luminary
DNS is NOT IP you will be using
See router status and look Internet ports
That is the IP uou use in URL with the ports
X.x.x.xSmiley Tongueort number
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
Novice
here is what THAT says:
MAC Address 28:C6:8E:07:03:0B
IP Address 66.169.62.73
Connection Static IP
IP Subnet Mask 255.255.252.0
Domain Name Server 24.178.162.3
66.189.0.100
24.217.201.67
Luminary
You have wrong DNS
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
Discussion Stats
  • 10 replies
  • 5618 views
  • 0 kudos
  • 3 in conversation
Top Contributors
