Reply
WNR2000 v3 & chromecast
Anyone get this to work w/o issues? I get most of way their and am told I need to change some settings on the router ie. disable PNP and guest network - huh?
Re: WNR2000 v3 & chromecast
Clarification - instructions were to "enable" UPNP which I did and disable Access point/guest network, which I did and still no connection.
Luminary
It may be that Chromecast relies on multicasting, and in the home routers from Netgear, it is disabled by default. To enable it, simply log in to the router, go to "WAN Setup" and make sure that "Disable IGMP Proxying" is not enabled (uncheck it). Apply the settings, restart your router and devices and give it another go now.
8/1 Mbit/s ADSL
Router: D-Link DIR-615
Wired AP: Netgear WNR1000v2
Luminary
Chromecast overall seems to have very flaky on connecting.
Most other had and issues with chromecast works after power cycle the router (on/off)
VPN Case Study
VPNCASESTUDY.COM
"Our Second To None VPN Related Setup Case Study[/COLOR][/URL]
"One Stop Solution To Your Netgear VPN Connectivity"
*Visit the site for Non-VPN related Doc & Links* [Windows & Mac user/support]
June Mizoguchi-
Okay, got it to work but only after getting the same error messages then selecting to install by Chromecast through the web. They had me manually connect to Chromecast on my tablet WiFi, then during the process, reconnect my tablet to my home network. Weird as my tablet saw Chromecast when connected to my home network in the normal install process. Now let's see if it will work on all my other TV's. Thanks for he replies - will add G2 if its meaningful.
Luminary
Must be some to do with chrome cast.
You will find to other chrome cast issues within the past month or two in this forum but they has network error showing up .
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
Discussion Stats
  • 5 replies
  • 5184 views
  • 0 kudos
  • 3 in conversation
Top Contributors
