PerlaFlowers15
Mar 13, 2018Follower
WNR2000 v5 N300 Router Middle Internet LED Not On
middle light not on
Hello, I bought a WNR2000 v5 N300 router 2 months ago and the middle LED- the one with the circle shape, is not on. I still have access to the internet but whenI try to play xbox online it says there is no internet connection. I tried disconncting it from the modem and powering it off and on but the light still won't turn on. Anyone have any suggestions? Thanks
Hi PerlaFlowers15,
1. Please make sure you go through the setup procedure. The inks below may help out.
http://kb.netgear.com/app/answers/detail/a_id/22697
http://kb.netgear.com/app/answers/detail/a_id/22717
2. Have you tried resetting the router?
3. You may also try MAC spoofing. The steps are linked below.
http://kb.netgear.com/app/answers/detail/a_id/1086
Dexter
Community Team
- DexterJBNETGEAR Moderator
Hi PerlaFlowers15,
Dexter
Community Team
Hi PerlaFlowers15,
I would like to follow up and check if you are still experiencing the issue.
Dexter
Community Team
