Reply
WNR2000v3 firmware update?
Genie says a firmware update is available and proceeding thru process steps outlined by Netgear support website I find version V1.1.2.10 available. I have V1.1.2.6 installed. However, running thru process Genie ultimately drops me back to "Home" page without connecting to Firmware Upgrade Assistant. When I try to step thru manually: Advanced>Updates>etc, it tells me no firmware upgrades are available?? Thanks
Tutor
Re: WNR2000v3 firmware update?
The Desktop Genie software is problematic and in my opinion is a waste of cycles. Instead, use a web browser and actually log into the router and perform the update from there. See signature link, step 4, for one way to properly change firmware. It may save you some grief.
_____
WNDR3700v1 (v1.0.7.98NA) - Router uptime (d:h:m:s): 1155:02:31:46 - How To Check and Change Your Router's Firmware: http://forum1.netgear.com/showthread.php?t=63234
Thanks Devor. That worked. Appreciate the rapid response!
Tutor
Probably this is the same problem:
I am using a WNR2000V3 with V1.1.26 firmware/software load.
I am in the router and asking for any firmware/software upgrades. It polls and returns saying there are "no updates".
However, when I go to the Netgear website looking for downloads for documentation and firmware/software downloads, there is a newer version: 1.1.2.10.
Am I supposed to ignore the "no upgrades" response and go to the downloads after the new version and download manually?
NetGear300 WNR2000 v3
Firmware Version V1.1.2.10
Used for:
NookColor
Toshiba Satellite A215- 32-bit
Toshiba Satellite P75- 64-bit
Tutor
Or, is 1.1.2.10 not an upgrade for me - it's getting confusing . . .
Used for:
NookColor
I have a different issue. I bought my router second hand and it has already been registered. I just wanted to use it for network hardware sharing. Is this possible and how do I get the firmware upgrade? :confused:
Virtuoso
The fact that a router has been previously registered should not prevent you from downloading firmware, you might have to skip any registration process you come across but there should be the option to download regardless.
Discussion Stats
  • 6 replies
  • 3643 views
  • 0 kudos
  • 5 in conversation
Top Contributors
