× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
Windows 7 not picking up IP address on WNDR3400 ethernet port
Hank4
I have just replaced a WNDR3400v3 with a new unit (same model) due to a failure of the old unit. The old unit worked very well with both WinXP (SP3) and Win7 (SP1). My system is a dual-boot system, so the hardware is the same for either OS. My problem is that now Win7 will not pick up an IP address from the router. WinXP still performs well, as it always has.
Any ideas?
Model: WNDR3400v3|N600 Wireless Dual Band Router
Message 1 of 3
Accepted Solutions
Retired_Member
Not applicable
Re: Windows 7 not picking up IP address on WNDR3400 ethernet port
icon.pngDelete all connections and then reconnect and choose home network
Message 2 of 3
All Replies
Retired_Member
Not applicable
Message 2 of 3
Hank4
For whatever reason, your method took three attempts ... but it did work. Thanks for the assist.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 2568 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
