- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Windowx X and RReadyshare not compatible
- Mark as New
- Bookmark
- Subscribe
- Permalink
i know my problem is with the new update and smb1 being disabled. i am assuming this is a problem with the router and not the hard drive. My question is will netgear put out an update for this fix or do I need to purchase a new router?
OS Windows 10 home
Version 1709
Build 16299.431
Router WNDR3400
Firmware Version | V1.0.0.52_20.0.60 |
GUI Language Version | V1.0.0.50_2.1.17.1 |
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Your question has come up quite a lot in recent times.
Try searching this forum for SMB1.
For example, here is one of many responses:
Solved: ALL Netgear USB Drive Mapping Issues ReadyShareCo... - NETGEAR Communities
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Windowx X and RReadyshare not compatible
It might help if you explained what the problem is.
The WNDR3400 (v1) is a basic router that dates from 2010. It is limited to 100BASE-Tx on the LAN and WAN, which means that it is slower than modern internet services.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
