- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
need wiring instructions to connect to an microwave antenna isp no modum
- Mark as New
- Bookmark
- Subscribe
- Permalink
i use a isp that is radio based i have no modum only a router - computer to router to antenna - all the wiring instructions include a modum. any help appreciated.
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
@TheEther wrote:Plug your router into that connection.
Yup. And use the Internet port.
The Installation Guide may help:
>>> WNDR3400v3 | Product | Support | NETGEAR <<<
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: need wiring instructions to connect to an microwave antenna isp no modum
Assuming that you have a WISP (Wireless ISP), there should be an Ethernet connection that they should have provided you. Plug your router into that connection.
- Mark as New
- Bookmark
- Subscribe
- Permalink
There has to some type modem like device to connect the antenna to a wired lan based router either cat 5 or cat 6 lan should coming from the antenna if is made in the antenna then a power over ethernet adaptor would inserted between the router and antenna.
Do you have a link to instructions from the isp?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
thanks got it.
