warning
2 TopicsCustom Alert Levels
Hi all, I have a ReadyNAS 2120 v2 and the level is 6.9.0 and I've see only the option to enable the alert or disable some items. I would to like to know if it's possible to modify the alerts sent to the mail, for example: default alert is "Less than 30% of volume RAID10's capacity is free" to notify me only under the 15% or similar. ThanksSolved1.2KViews0likes2Comments
