00:00:00:00:00:00
1 TopicInvalid arps received from GS724Tv4 ProSafe 24-port Gigabit Ethernet Smart Switch
The switch is configured with four ports (ports 9 - 12) for VLAN 114. Port 24 is configured as a trunk port used for uplink to a router. VLAN Status 114 B5-K05 VLAN 114 Static g9 - g12, g23 - g24 VLAN Membership 9 10 11 12 24 T T T T T Interface PVID VLAN VLAN member tag Ingres filtering Port priority g9 114 114 114 114 Admit All Enable Enable 0 Each port is patched via a patch panel to a RJ45 wall socket When I connect a Windows machine access to other devices on the local subnet is ok, and internet access is ok Then comes the issue: When I connect a PC running Linux or a Mac local arp table shows invalid entry where default GW (accessible though the switch) IP address have a mac address of 00:00:00:00:00:00 Obviousely the Linux or Mac can't communicate since there is no valid destination mac addresss to send the IP packets. I hope to get help to resolve thisSolved9.5KViews0likes4Comments
