5 GHz
1 TopicEX6150 - 5 Ghz - On which channels can it connect on router ?
Hey Guys, I have bought a Linksys RE6400 Extender and I discover that it cannot connect on my router over others channels than 36-48. It is a problem for me because the channels 36-48 are stupidly over used in my street. And I will not speak about the 2,4 Ghz channels ;-) Now, I'm looking on Netgear side. Is the EX6150 able to connect over 5 Ghz channels others that 36-48 ? Like 52-64 or over the 100 ? Thanks for your time,Solved5.5KViews0likes5Comments
