6.1.6
2 TopicsReadyNAS 314 - Firmware update from version 6.1.6 to 6.6.1 Issues
Will there be an issue when we update the firmware of the ReadyNAS from version 6.1.6 to 6.6.1? We have encountered an issue with another Netgear ReadyNAS losing the volume when we update to the latest firmware. We had logged a case with Netgear support to recover the data for that issue. We are planning to update the firmware on the NAS to see if it will fix the folder permission issue we are having. Currently we have a shared folder (UserProfile) that we cannot see the contents inside via the webui. We are able to see the contents inside if we access the shared folder via SMB on a Windows 7 PC. Please advise if anyone experience any issues updating a very old firmware on the NAS to the latest.3.5KViews0likes3CommentsInstallation problem - invalid caracter - hostname
Hi, I have a problem filling out the hostname on screen two when setting up Photos II and it does not allow med to go further on. It seems like it should be filled out from before, however it is empty. When trying to fill out and set the hostname the error message is invalid caracters. I found some other posts on the subject from 2014 but that gave me no answer. Tried and failed: Reinstalling Photos 3 times Using Chrome, Safari and even from iPad (since one post reported browser as a problem) Changing the name of the server I'm not very Linux savy, but I get around and can do some changes if needed. Any advise would be most helpful.
